How to add cleaner to flush hot water baseboard system
dough041
dough041 Member Posts: 34
Probably a stupid question but , I am looking to replace an older utica gas fired hot water baseboard system with a mod con. Should I just flush the lines good with fresh water before disconnecting the old unit or should I add some boiler “cleaner” , run it to circulate the cleaner then flush and refill with fresh water? Also I have some hercules boiler/system cleaner, how would I add it to my closed system? Thanks for any help. I will be adding all new pumps, diret seperator etc…
    hot_rod Member Posts: 27,446
    Flush with water pressure. Use the Hercules after you install the new boiler to get all the flux, oils, pipe dope, etc  out
  • dough041
    I guess the question I have is how to I physically pour/add the quart of boiler “cleaner”?
  • EzzyT
    EzzyT Member Posts: 1,379
    You’ll need to pump or inject it into the system.
    Most of the hydronic cleaning & inhibitors chemicals companies have injectable cans that one would use a boiler to get into the system.
    But as @hot_rod has said you need water pressure in order to due the right job of system flushing.
    A flush cart is what is needed.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
