HELP Bradford White Brute FT Series Wall Mount Boiler
Tullia
Tullia Member Posts: 3
edited June 2023 in Gas Heating
Hello. Hoping someone can help with my problem. My boiler won’t turn on. I get the following on the display screen and I cannot find the info in my manual.
Pdn
0071
SPn
00.04
SFn
sometimes 0009 appears last.
Thank you for any help.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,388
    Did you Try Brad White Tech Support? Mad Dog 🐕
  • Tullia
    Yes. And after being run around on for 45 mins with people who didn’t know anything about a boiler because those people weren’t anywhere to found I hung up. I even left voice messages with people who were supposed to be at their desks and were not.
    Mad Dog_2
    mattmia2 Member Posts: 15,564
    What does the manual say?
  • Tullia
     Nothing. Because those are not error codes. They are the letters/numbers that come up on startup. It’s just stopping before it’s finished.
    oh, so it isn't booting, that is just the firmware version and such? Sounds like you need to talk to whoever at the manufacturer knows the firmware on those. Check the power too.
  • HomerJSmith
    HomerJSmith Member Posts: 2,710
    edited June 2023
    Try unplugging it from the power for several hours and re-plug and see if it starts. also, when there isn't any power to it, press the power button and hold for several min.
