HELP Bradford White Brute FT Series Wall Mount Boiler
Tullia
Member Posts: 3
Hello. Hoping someone can help with my problem. My boiler won’t turn on. I get the following on the display screen and I cannot find the info in my manual.
Pdn
0071
SPn
00.04
SFn
sometimes 0009 appears last.
Thank you for any help.
0071
SPn
00.04
SFn
What does the manual say?0
Nothing. Because those are not error codes. They are the letters/numbers that come up on startup. It’s just stopping before it’s finished.0
oh, so it isn't booting, that is just the firmware version and such? Sounds like you need to talk to whoever at the manufacturer knows the firmware on those. Check the power too.0
Try unplugging it from the power for several hours and re-plug and see if it starts. also, when there isn't any power to it, press the power button and hold for several min.0
