Trouble Removing a soldered fitting
what am i doing wrong?
can over heating a fitting bring it to the point of irreversibly joined?
You've over cooked it. You might give it one more shot. Heat it up but no too much. Use a generous dab of Flux and try to force it in to the joint. Keep the majority of heat away from the joint..favor the fitting. Use 440 Channelocks to try and twist it off...add more Flux if needed. Back and forth, it should come off. Once you get elbow off, take a 3 M pad and wipe all solder globs off. Clean off pipe with clean damp rag removing all Flux. Now wipe immaculately clean with a clean, dry rag. Now use open mesh grit cloth and clean to a high shine. Fresh Flux on pipe & fitting. Don't over heat...resolved. worth a shot. Mad Dog 🐕
Mad,Mad Dog_2 said:You've over cooked it. You might give it one more shot. Heat it up but no too much. Use a generous dab of Flux and try to force it in to the joint. Keep the majority of heat away from the joint..favor the fitting. Use 440 Channelocks to try and twist it off...add more Flux if needed. Back and forth, it should come off. Once you get elbow off, take a 3 M pad and wipe all solder globs off. Clean off pipe with clean damp rag removing all Flux. Now wipe immaculately clean with a clean, dry rag. Now use open mesh grit cloth and clean to a high shine. Fresh Flux on pipe & fitting. Don't over heat...resolved. worth a shot. Mad Dog 🐕
Why flux for removing the pipe from the joint?
can a joint like this get to the point where it is permanently fused together0
If he had it glowing there isn't water in it.Big Ed_4 said:There is still water in the pipe . You can't raise enough temperature to melt the solder with the water absorbing the energy . Cut a drain hole in the fitting to drain the water ........
If it glowing , you fired the connection , you have to go back further on the line to get good pipe .
What is on the other side of the wall? What is the wall made of? If it is an outside foundation wall, then you may be digging a trench to replace that pipe from the opposite side of the wall. If it is just a plaster or sheet rock wall, than you just need to remove some wall, make the repair, then patch the wall board or plaster. Plumbers may need to do a little plastering from time to time. Unless it's on a Union Job!
EdTheHeaterMan said:What is on the other side of the wall? What is the wall made of? If it is an outside foundation wall, then you may be digging a trench to replace that pipe from the opposite side of the wall. If it is just a plaster or sheet rock wall, then you just need to remove some wall, make the repair, then patch the wall board or plaster. Plumbers may need to do a little plastering from time to time. Unless it's on a Union Job!0
What if it is tile?EdTheHeaterMan said:What is on the other side of the wall? What is the wall made of? If it is an outside foundation wall, then you may be digging a trench to replace that pipe from the opposite side of the wall. If it is just a plaster or sheet rock wall, than you just need to remove some wall, make the repair, then patch the wall board or plaster. Plumbers may need to do a little plastering from time to time. Unless it's on a Union Job!
Like @Larry Weingarten said, if you cut or tear the outer fitting and start pulling pieces off, it will peel off of the solder cold then you can clean the solder off the nipple.0 -
Chris....Flux will lubricate the annular space and let it slide off. Cherry red is close, but its not welding it together. Great idea on PPE..I don't worry about my face..just the eyes 👀...Mad Dog 🐕1
sometimes under the right conditions things weld without melting. it is usually called seizing, but if they rub together right they can bond.Mad Dog_2 said:Chris....Flux will lubricate the annular space and let it slide off. Cherry red is close, but its not welding it together. Great idea on PPE..I don't worry about my face..just the eyes 👀...Mad Dog 🐕
that being said this is more likely they distorted such that they won't come apart2 -
I once installed a return grill on a plaster wall. I used a fine tooth blade on my reciprocating saw (several actually) to make the opening in the wood lath. there was a small crack that looked like it would be just fine. The next day I returned to install the covers on all the supply openings in the floor and the one return opening in the wall. That cover caused about 4 feet of plaster to dislodge from the wall. My stomach dropped when that happened. The home owner was sort of OK with it. I cleaned up the mess I made and went to the truck to fetch some Structo-Lite® Basecoat Plaster. You may recall from other posts that I use it as chimney base cement on furnace maintenance. There was just enough to cover the lath that was exposed by the mishap.pecmsg said:I’d be concern with Wood Lath!
The following day I brought some drywall installing tool and a bucket of premixed drywall compound. After one coat of that MUD, I continued to install the rest of the duct system in the home. The following day I sanded and layed a second coat of mud. The wall looked as good as new. The homeowner had some matching paint in the basement. On the last day of the job, a coat of paint made the wall look as if nothing had ever happened. I was impressed that I was able to make that happen. Since then, I have no fear when it comes to opening walls. Everything man made can... be made again!
Are there extra tiles in the basement or garage?mattmia2 said:What if it is tile?
If they are really old tiles then get something close and get creative. Paint, Stencils, or a boarder of new tile or maybe add a return grill to cover the opening for future access. There are some pretty fancy grills and covers available to match all types of decor.https://www.youtube.com/watch?v=CxRB_9NRbyc
I do agree you can braze with silver rod . But I would not against a concrete wall .
Sometimes they ARE beyond getting them apart, but its worth one good shot...I get 90% of them apart and resoldered like that. The joint is all filthy and cooked, the Silver braze might not take, but you have nothing to lose trying. I agree about being able to get egged copper back in to round. Run an Orange 🍊 Ridgid Round mini cutter or #15 around the end leaving the cutting wheel flush against the edge if the cut pipe. If this joint were out in the open, I wouldn't waste time and would just cut it out. However, since it is flush up against a Wall and a headache to do that, the extra time is worth it. Mad Dog 🐕1
final update. thank you all for your prompt feedback and suggestion'
I cut the elbow fitting and peeled it off. to close to the wall to cut pipe, would have left a 3/4-1" of exposed pipe to work with; and cutting into wall was not a task i wanted to add to this job if possible. apparently the pipe was deformed and very soft. the elbow was pushing against the water heater, so over the years and WH changes it got banged up. also, some of the solder wouldn't heat up and run, even with direct heat. I trimmed the pipe back a 1/4" and rounded it out, sanded, and soldered new fittings and extended away from the back of the WH. this was a High temp water over flow drain pipe. I gave it a little pitch and it is about level with the HTOF valve. the previous setup was just about level too. but their was a lot of corrosion and rust on the valve and pipe. unfortunately this setup doesn't allow air to flow through discharge hose to aid in evaporation after discharge or HT valve annual test, as it is in a condo building.0 -
When you heat the pipe especially when it isn't going well you anneal the copper and make it softer. Doesn't affect it enough for the pressure you're dealing with but it makes it bend a lot easier.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 993 Plumbing
- 389 Solar
