For the Plumbers.....
Mad Dog_2
Member Posts: 8,434
Check out this F.A.I.!!! Very cool 😎. I always disagreed with some codes that stated Fresh Air Inlet could be as low as 6" A.G. What about SNOW ❄ 🤔? Mad Dog 🐕0
Actually, snow -- unless it is very densely packed -- allows a fair amount of air passage. Probably enough for a simple plumbing vent. Though nowhere near enough for the intake for a boiler, for instance.Br. Jamie, osb
You're questioning code and something that has worked for over a century?Mad Dog_2 said:Check out this F.A.I.!!! Very cool 😎. I always disagreed with some codes that stated Fresh Air Inlet could be as low as 6" A.G. What about SNOW ❄ 🤔? Mad Dog 🐕
2 -
Yes Chris...Never drank The Kool-Aid like some people....When something doesn't make sense, I'll call it out.... By the way, I install MY fresh air inlets higher. Why don't you edify us on your knowledge of the ICC...
Ever actually install one? Mad Dog 🐕2 -
I've never seen such an ornate F.A.I...that's
Why I posted a picture.
It looks like the top can be removed for rodding the building house drain, but I was already pushing it 😅 being in their front yard. I've seen old ads for Plumbing and heating items that they hyped up their products as if they were earth-shattering inventions. What is there to "regulate" ? You want maximum air flow on a Building House drain and sewer. Just a hyped up gimmick, perhaps, but I thought it looked really cool 😎. Mad Dog 🐕1 -
@Mad Dog_2 No not only are house traps not used here, most feel they're an unnecessary headache and rip them out when found.
So it's very unlikely I'll ever install one.
The few I've seen were older.... But I would guess 1950s-60s. They were typically just a perforated metal cover on the foundation. Nothing fancy like your picture.
