Word of the day
ChrisJ
ChrisJ Member Posts: 16,853
The word of the day is :
Stoßlüften
 That is all. :)
kcopp
  • unclejohn
    unclejohn Member Posts: 1,833
    Im shocked that your ventilating.
    ChrisJ
  • ChrisJ
    edited June 2023
    @DanHolohan Have you ever written about this German behavior?
    For some reason my phone autocorrected "this" to "smut" and my wife wanted to know why I was laughing.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,643
    I've never heard of that, Chris.
    Retired and loving it.
  • ChrisJ
    Apparently it is, or was common in Germany, especially public buildings to shut off radiators and open windows wide open to abruptly ventilate and get fresh air in.
  • DanHolohan
    Learning every day! Thanks.
    ChrisJ
  • bburd
    bburd Member Posts: 1,173
    edited June 2023
    When I was in Germany (35 years ago) this was described as a way to control excess humidity and resultant condensation in homes during the winter. A different term was used, I don't remember it exactly. Zwangslüftung?
    Bburd
    ChrisJ
  • Derheatmeister
    Derheatmeister Member Posts: 1,658
    Yes it used to be called " Zwangslüftung" which translates to " force ventilation."..Most New Yorkers call this a Double hung thermostat :D ...IAQ in Germany has come a long way from these window opening days..
    bburdPC7060
  • Derheatmeister
    Most of the german windows have a tilt function which allows the window top to be cracked open just a bit ...My Oma would sleep with the window tilted open and a very heavy down feather comforter that was about 40 CM thick(16 inch). Of course the heat was not on during this time.
    This would be "Dauerlüftung" without all the bells and whistles.
    In the morning the Comforter was aired out on the open windowsill
    Heat recovery is gaining great acceptance now and the days of leaving the window open will most likely disappear by energy saving regulations.
    On one of my last visits one of the Vrbo's near Stuttgart had a switch on the window that turned off the heat when the window was opened.
    PC7060
  • JUGHNE
    JUGHNE Member Posts: 11,461
    While visiting base housing in Germany almost 50 years ago the airing out was a practice I was told of.
    Almost everyone smoked then and that was reason enough.
    PC7060Derheatmeister
