Delta shower diverter replaced, still has water leak on bottom spout.
I replaced a new water diverter, here is the results:
https://youtube.com/shorts/6IuiIA4J6ms?feature=share
There is still some water leaking thru the bottom spout. Any idea what is going on?
Thanks
Thanks
great idea, thanks0
How do I hide the original diverter and only use the tub spout diverter? otherwise I will have 2 diverter, looks strange.0
Get used to it...looks fine. You're asking for trouble if you keep messing with it. Mad Dog 🐕1
Could be high water pressure causing it. This
old house has a u tube video out with that problem but it's probably the diverter0 -
I have a very small dribble with all Kohler diverters similiar to you. Both the summer and winter residence. Both are spout diverters. Not sure I have ever seen one that works 100%.0
- 50 Industry Classes
