Delta shower diverter replaced, still has water leak on bottom spout.
zhenying
zhenying Member Posts: 19
I replaced a new water diverter, here is the results:
https://youtube.com/shorts/6IuiIA4J6ms?feature=share
There is still some water leaking thru the bottom spout. Any idea what is going on?
  • zhenying
  • kcopp
    kcopp Member Posts: 4,661
    Those diverters wear out. The simplest fix is to install a diverter tub spout and it will serve the same function.
    zhenyingMad Dog_2
  • zhenying
    great idea, thanks
  • zhenying
    How do I hide the original diverter and only use the tub spout diverter? otherwise I will have 2 diverter, looks strange.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,499
    Get used to it...looks fine.  You're asking for trouble if you keep messing with it.  Mad Dog 🐕
    kcopp
    EBEBRATT-Ed Member Posts: 20,041
    Could be high water pressure causing it. This
    old house has a u tube video out with that problem but it's probably the diverter
  • scott w.
    scott w. Member Posts: 226
    I have a very small dribble with all Kohler diverters similiar to you. Both the summer and winter residence. Both are spout diverters.  Not sure I have ever seen one that works 100%.
