Electric Tankless Water heaters
SweatHog
Member Posts: 30
My plumber says electric tankless water heaters (for a kitchen faucet) are trash and that I should get a tankless gas heater. But I have solar and a gas boiler with an electric water heater during summer months. I think gas for a single kitchen faucet would be overkill and require way more disruption to install and maintain. The other optioni is to add a hot water circulation circuit. But it's a long run to the kitchen. and the pipes aren't well insulated. What's the best choice here?
What is the goal? Are you trying to reduce wait time for hot at the kitchen?
Either a small electric heater under the sink, or a recirc loop of some sort.
Any electric tank will require element replacements occasionally, depending on how hard your water is, how much passes through and temperature.
It is nice having 130- 140 at the sink and dishwasher. Soaps work better, grease gets gone easier.Bob "hot rod" Rohr
What is your goal? With an under sink point of use instantaneous water heater rated at 120v, 3.5kW, with a 29A draw will net you a 12 deg F rise in temperature at 2.0 gpm. Drop that to .5 gpm and you can get a 48 degree rise. Not very impressive. A small 4-6 gallon 115v tank is a much better idea.0
Eemax EMT4 or EMT60
A 6 gallon tank type should be plenty, it's probably 1300W, got enough power? Any tankless or instant will take a lot more power.
These take off the shelf repair parts.
It is nice to have a pan and drain under a water heater in a cabinet like that. It will leak someday.Bob "hot rod" Rohr
Look in to the Taco or Grundfos undersink Tee system with a HW recirc. On the water heater. Uses the Cold water as a HW return...works very well. Mad Dog 🐕0
Stieble Eltron makes nice waterheaters..
Low Energy products in Denver can help with all your hot water needs.
1800 873 35070 -
Never hurts to check the cost of repair/ consumable parts. OEM parts tend to be more$$
All the 6 gallon tanks use this common screw in element.Bob "hot rod" Rohr
Living the hydronic dream1 -
Hi, Two options/refinements. A small tank the least expensive. To size it, run water until it begins to warm. Catch and measure the cold water. Make the tank at least three times that number of gallons, so if you run out two gallons, get at least a six gallon tank. This approach limits the temperature drop that can happen... Gothotwater.com developed the demand recirculation approach. Push button, get hot water
Yours, Larry1
- 15.8K Strictly Steam
