Honeywell Actuators
Member Posts: 4,695
From what I remember, Honeywell took over the Sparco line and then these were discontinued. Is there a replacement?
Originally Sparco Powertrack, then Honeywell Sparco. Wirsbo and maybe Embassy used them also.
I suspect a thermal actuator may work also. Need to try one on an old manifold if you ever come across a manifold changeout.Bob "hot rod" Rohr
Living the hydronic dream0
- 117 Geothermal
