Honeywell Actuators
From what I remember, Honeywell took over the Sparco line and then these were discontinued. Is there a replacement?
    Alan (California Radiant) Forbes Member Posts: 4,808
    edited May 2023
    But now that I've written it down, it occurred to me that I've seen that style before. I dug through my contraband and found these unused Wirsbo ones which look identical. Thanks, everyone!
    GGross
    hot_rod Member Posts: 27,859
    Originally Sparco Powertrack, then Honeywell Sparco. Wirsbo and maybe Embassy used them also.
    I suspect a thermal actuator may work also. Need to try one on an old manifold if you ever come across a manifold changeout.
