Radiantec Smartwall tubing
Jeff Perry_3
Member Posts: 102
Lucky me has a job with 3 zones of 5/8 Radiantec Smartwall tubing. Their idea of a manifold is their fittings, ball valves and a copper header. No flow meters. I wanted to install a standard manifold like Rehau or something. Their tubing is odd sized and no matter what I have tried no R20 or compression fitting will allow me to transition to a standard 5/8 PEX fitting to let me use my manifold.
Anyone else ever have to deal with this?
Is there any listing on the tube to give you an idea of what fitting will match?Jeff Perry_3 said:Lucky me has a job with 3 zones of 5/8 Radiantec Smartwall tubing. Their idea of a manifold is their fittings, ball valves and a copper header. No flow meters. I wanted to install a standard manifold like Rehau or something. Their tubing is odd sized and no matter what I have tried no R20 or compression fitting will allow me to transition to a standard 5/8 PEX fitting to let me use my manifold. Anyone else ever have to deal with this?
If you know the OD, a metric R-20 may workBob "hot rod" Rohr
That's a shame. I never saw any reason to switch from the original, Wirsbo/Uponor...why? To save a few bucks? Used Slant Fin a few times when that's what was spec'd for job. No problems with the tubing, but wasn't crazy about the Manifolds and lawn sprinkler clamps. They had a class action lawsuit against them when they failed and they suddenly dropped the whole radiant line.. That was the beginning of the end of an otherwise great,, Local, Long Island Manufacturer. Mad Dog0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
