4B gas boiler
I can not get my boiler to fire up after shutting  it off to clean it
    109A_5 Member Posts: 3,829
    Hello @mousy,
    Revisit every thing you touched during the cleaning. If it has worked flawlessly until now, it is probably something that was touched or a failure as a result of the cleaning. Power on, Gas on, all wiring connections intact ? If that reveals nothing either you or a pro will have to troubleshoot it to discover the present defect.
  • JUGHNE
    JUGHNE Member Posts: 11,542
    Does it have a standing pilot flame or electric ignition?
    If you shut off the gas supply, it would have shut off the pilot light and it must be relite.
    EdTheHeaterMan Member Posts: 11,964
    edited May 2023
    B4 I give any advise, I would like to know what a 4B boiler is!
    Get it? B4. 4B. Get it?
    Pictures, Age, Controls, Gas Train, more pictures?
