4B gas boiler
mousy
I can not get my boiler to fire up after shutting it off to clean it
Hello @mousy,
Revisit every thing you touched during the cleaning. If it has worked flawlessly until now, it is probably something that was touched or a failure as a result of the cleaning. Power on, Gas on, all wiring connections intact ? If that reveals nothing either you or a pro will have to troubleshoot it to discover the present defect.
One Pipe System0 -
Does it have a standing pilot flame or electric ignition?
If you shut off the gas supply, it would have shut off the pilot light and it must be relite.0 -
B4 I give any advise, I would like to know what a 4B boiler is!
Get it? B4. 4B. Get it?
Pictures, Age, Controls, Gas Train, more pictures?
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
