RPZ BFP brands / models recommendation
ChrisJ
Member Posts: 17,210
Looking for a recommendation for an RPZ for 1" residential water service.
This will be inspected by the water company annually.
I see Watts 009 and Caleffi 574..... No idea if either is decent or if they are which is preferred.
We are switching our stock from the conbraco models to the caleffi. Seems that in other markets people get particular about which brand RPZ they install. Caleffi, Watts, Conbraco, seem to be the good brands. I am switching to Caleffi personally because they make parts ordering super simple, and Caleffi delivers product on time! They also are one of the few companies that makes an effort to educate their customers. I vote caleffi all the way2
NYC market is specified ~70% Watts, 30% Wilkins
With Watts going nuts with increases, a lot of Wilkins crossovers.
No experience with any other RPZ. We would only recommend one of the above here as you can always find repair kits for them here, any other brand would be special order.
Watts LF009 is the bread and butter RPZ of choice. I don't sell too many repair kits, so that's a good sign?1 -
The Caleffi comes with the "tundish," aka air gap.
I believe it is an add on $$ for the Watts.
This is required if you install a discharge tube, as you should. And have it inspected.Bob "hot rod" Rohr
Living the hydronic dream2 -
Is this for your new water service line?
A new requirement of they just caught up with you?
An expansion tank is in order?0 -
No this is for my boss who doesn't want to decommission his well at this time but wants city water.JUGHNE said:Is this for your new water service line? A new requirement of they just caught up with you? An expansion tank is in order?
They said if he wants both he needs the bfp.
My install was inspected and passed. Caught up with me.....jeez. is that what you think of me?
No this is for my boss who doesn't want to decommission his well at this time but wants city water.ChrisJ said:JUGHNE said:Is this for your new water service line?
</blockquo
I am 9.9999% sure you cannot under ANY circumstances connect a not potable water supply to a potable water supply. If you have a Municipal supply (city) any other supply is a NON potable water supply.
This applies even if you connect w/ an RPZ.
If he wants to water his lawn then all piping has to be pulled out of the Potable supply.
2 -
@kcopp
His well will be disconnected from the system but the water company insisted on the rpz unless the well was totally decommissioned and filled.
There's a few reasons he doesn't want to go that route right now so the rpz will be installed as per their directions.
Febco or Zurn Wilkins are the most common in NYC & Long Island 🏝. Both are very good. Wouldn't hurt to check with the particular water district specs as to which brands are on their OK list and acceptable locations. With Dozens of water districts in Nassau County, they are all slightly different on what the want. Mad Dog1
- 116 Geothermal
- 169 Indoor-Air Quality
