Not enough hot water
JW2023
Member Posts: 4
Recently our hot water only lasts a few minutes then runs cold wait a while and then it's hot again.
Tankless?0
Broken dip tube if it is a conventional hot water heater0
We have a 4400 wood master outside stove0
It is a single family house it occurs in the kitchen sink and in the bathroom also so whole house0
So it is a tankless coil?0
No coil just a tank it's an outdoor wood furance tied into hot water baseboard in the house0
Maybe you need more wood ... Normally the hot water and boiler water is seperated. If there is only one unit your hot water is heated though a tankless coil . There was an error rendering this rich post.
Hi @JW2023 , Have you checked for a crossover in the piping? Is there a tempering valve that's scaled up? I'd like to see a photo of the wood furnace piping connections and surrounding piping... By the way, checking for a crossover is pretty easy. Just shut off the cold supply to your heater and open a hot tap. It should stop running in seconds. If it doesn't, cold water is getting in someplace.
Yours, Larry0 -
- 117 Geothermal
