Piping
Not allowing for expansion and lousy solder joints because whoever is doing it doesn't have the tools and or skill to solder 2 to 3" copper pipe.Jamie Hall said:
There are places where it's no problem -- I wouldn't hesitate to use copper on a wet return, for instance. Usually the problem with copper on steam is not allowing for expansion, rather than corrosion problems.BruceLundeen said:Good information about pipe. But nobody said something that I don't do but see all the time. Don't be putting a quick-fix copper pipe into a steam or hot water system. We think that brings down the whole system by causing electrolytic corrosion.
@AlfredRose -- your post would have been MUCH better as a new thread.Br. Jamie, osb
There were a few sections of 1/2 galv pipe I pulled out of the bathroom that weren't in use since the 1950s and I suspect were installed in 1910 along with a section of lead drain pipe and those galv pipes were also full of rust and minerals.Jamie Hall said:All I can say about black iron -- old -- and galvanized steel for piping is that I have had to replace every inch of galvanized steel pipe in the properties I maintain because it rusted shut or nearly so on the inside, making it somewhat useless as a pipe... whereas the black iron piping in the same properties has been in place for over a century, and the only leaks I've had were where it was in contact with mortar or in one place where a threaded joint developed a drip.
So..... Were those iron or steel from 1910?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Wasn't he the OP ? ☺️Jamie Hall said:@AlfredRose -- your post would have been MUCH better as a new thread.One way to get familiar something you know nothing about is to ask a really smart person a really stupid question0
- 117 Geothermal
