Need valve for radiator
I am thinking they are Runtal panels, check around for a marking .
Italian Fondital radiators imported by ModernWarmth sold on wayfair.com (model Blitz)
Valve is:
Discontinued 2021, so will probably have a difficult time finding it around here. If they were rebranded, they would have been taken off the websites and replaced by now so can't find. I only see remaining stock available for sale in the UK.
But as you are looking for a thermostatic valve, just search for 1/2" angle thermostatic valve. In your case, you have a pex compression fitting so you may not have the space for buying the more common threaded valve then adding a thread x pex adapter. Will need to find similar pex compression valve.
https://www.supplyhouse.com/Caleffi-200000-Thermostatic-Control-Head-with-Built-in-Sensor-45-82-F
https://www.supplyhouse.com/Caleffi-681524-1-2-Nominal-Pex-Fitting
You will need one of each to make a complete valve with pex compression. The dimension from center of valve to end of the radiator side threads is 53.5mm vs 53mm. Will line up fine.
Above is just an option and to get you an idea of what to look for.
You just want a handle that fits that broach, right?0
Yes something I can use to control the heat flow.mattmia2 said:You just want a handle that fits that broach, right?0 -
They are Nova Florida but I do have a Runtal in another room. A lot of the heating mechanisms are European. So finding replacement parts is very difficult.Big Ed_4 said:I am thinking they are Runtal panels, check around for a marking .0 -
Sounds like a lot. I would need a plumber or heating professional make that switch.dko said:Italian Fondital radiators imported by ModernWarmth sold on wayfair.com (model Blitz)
Valve is:
Sorry, thought you were looking to switch it to a thermostatic valve (automatic) vs manual.
Could eventually find something to fit the existing threads with more research or just trial and error, but you could also find a universal handle replacement that uses a multiple set screw jaw to retrofit over the stem.0 -
That’s still an option. If I can’t find a handle then my next option would be to switch it out with a TRV.dko said:Sorry, thought you were looking to switch it to a thermostatic valve (automatic) vs manual. Could eventually find something to fit the existing threads with more research or just trial and error, but you could also find a universal handle replacement that uses a multiple set screw jaw to retrofit over the stem.0 -
