Need valve for radiator
SugarRay900
SugarRay900 Member Posts: 12
Hello everyone. This is my current valve and radiator. I think it’s European. Should I replace it with a more common valve that can fit a TRV? I cant find a valve handle to fit it. What valve can I put on to control the heat? Is there a name? Please help.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    edited April 2023
    I am thinking they are Runtal panels, check around for a marking .
  • dko
    dko Member Posts: 669
    edited April 2023
    Italian Fondital radiators imported by ModernWarmth sold on wayfair.com (model Blitz)
    Valve is:
    Discontinued 2021, so will probably have a difficult time finding it around here. If they were rebranded, they would have been taken off the websites and replaced by now so can't find. I only see remaining stock available for sale in the UK.
    But as you are looking for a thermostatic valve, just search for 1/2" angle thermostatic valve. In your case, you have a pex compression fitting so you may not have the space for buying the more common threaded valve then adding a thread x pex adapter. Will need to find similar pex compression valve.
    https://www.supplyhouse.com/Caleffi-338452-Angled-Convertible-Thermostatic-Radiator-Valve-for-Towel-Warmer-Style-Radiators
    https://www.supplyhouse.com/Caleffi-200000-Thermostatic-Control-Head-with-Built-in-Sensor-45-82-F
    https://www.supplyhouse.com/Caleffi-681524-1-2-Nominal-Pex-Fitting
    You will need one of each to make a complete valve with pex compression. The dimension from center of valve to end of the radiator side threads is 53.5mm vs 53mm. Will line up fine.
    Above is just an option and to get you an idea of what to look for.
    mattmia2 Member Posts: 16,765
    You just want a handle that fits that broach, right?
  • SugarRay900
    Yes something I can use to control the heat flow.
  • SugarRay900
    They are Nova Florida but I do have a Runtal in another room. A lot of the heating mechanisms are European. So finding replacement parts is very difficult.
  • SugarRay900
    Valve is:
    Sounds like a lot. I would need a plumber or heating professional make that switch.
  • dko
    edited April 2023
    Sorry, thought you were looking to switch it to a thermostatic valve (automatic) vs manual.
    Could eventually find something to fit the existing threads with more research or just trial and error, but you could also find a universal handle replacement that uses a multiple set screw jaw to retrofit over the stem.
    Maybe wait until @hot_rod sees this, he is usually good with parts for european stuff.
  • SugarRay900
    dko said:
    Sorry, thought you were looking to switch it to a thermostatic valve (automatic) vs manual. Could eventually find something to fit the existing threads with more research or just trial and error, but you could also find a universal handle replacement that uses a multiple set screw jaw to retrofit over the stem.
    That’s still an option. If I can’t find a handle then my next option would be to switch it out with a TRV.
  • SugarRay900
