Domestic hot water
pipers
Member Posts: 21
Eastmond fire tube boiler with domestic tank less coil, when there is steam and radiators are hot domestic hot water is at about 140* to hot to the point of burning but when radiators are cold in the apartment the hot water is at about 100* and runs cold pretty fast
Your need a Hold Valve; Taco valce and Several companies make electronic ones with digital displays Heat Timer, The Brain, et
cetera. Mad Dog
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
