What is the normal connection for a gas appliance with a flexible hose?
Flexible hose has one compression end and one threaded end. My gas supply has a threaded connection. Do all gas appliances have pipe threads to accept compression adapters? h
I had to disconnect my gas dryer in a hurry to hook up a 30K BTU ventless gas heater in a heating emergency. Now I have to reconnect the dryer and would like to make a mini manifold.
Do flexible hose connections to supply have to be vertical?
yes all gas appliances have npt connections
the flex does not have to be verticle but flex connectors can only be used at the appliance to connect it to the gas supply
do not use any compression fittings proper flex connectors use flare connections
You gas supply will have to be large enough to run both appliances. You need gas shut offs near all appliances within close proximity
If your not familair with gas work you should call a licensed plumber or gas fitter. This is required in some locations. Homeowners doing gas if allowed in you area will likely require a permit and maybe pressure testing or at least soap buble testing. Gas can be very dangerous if not done properly use caution
By threaded hose, you mean CSST yellow metal connector? A CSST connector has two flared ends that fasten to the flared connector on the appliance and one flared connector on the gas valve. Yes, you can do that but you need a separate gas valve for the heater. It can be done like it is done for a barbecue with a plug-in gas connector. Still need the extra gas valve before the plug-in. The connection can be in any direction, but horizontal is preferable.
I connected the yellow flexible hose to the dryer, recently removed it, and connected hose attached to the ventless heater. Now I will go back. I did the previous two OK after soap buble tests and explosive gas monitor. I was leaving the piping alone but thought fa making a mini-manifold past the local gas ball valve. I examined theflexible hose in the bag I had. It has two flared ends (I mistakenly called them compression fittings). This hose is for range and furnace. There are two male to male flare to male pipe thread adapters with one 1/2 I would guess and the other around 5/8 I guess. Not using this one, I have two in service right now.
I looked at my oven. There is a male pipe thread to flare adapter at supply and oven with flare sticking out to receive the female flex hose fitting.
Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.0 -
- 15.8K Strictly Steam
