A Quick Survey: Boilers with Common Venting
Have you ever worked on boilers with common venting? If so, one of our partners would love to hear your thoughts in this 3-minute Boiler Common Venting Survey.
Thank you!
HeatingHelp.com
D
D
Done
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Done
Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Just clicked the "DONE" button.
Thanks, @Solid_Fuel_Man, @STEVEusaPA, @Intplm., and @Allislandradiant!
The manufacturer is anonymous for this survey. Thanks!
President
HeatingHelp.com0 -
Still tons of atmospherics Jumper...youre .opinion means a lot. Mad Dog
What I remember is issues.
•Close flue from inactive boiler: how to failsafe that it's open before firing?
•What about spill hoods with small boilers when chimney is big & tall? How to ensure "overpressure/underpressure"? What about powered chimney booster?
•Will chimney condense/ ice when sole big boiler is replaced?
Building owners found some fuel saving when replacing big boiler with multiple smaller ones.
Done
Please consider sharing your thoughts in this survey if you haven't done so yet. Thank you!President
HeatingHelp.com0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
