Herman Nielsen Invisible Radiators ~1930
jlt83
Member Posts: 11
Does anyone know of any potential sources for parts for the radiators housing / vents. I have a house full of these radiators with broken damper gears / control knobs and some missing the entire radiator “face”.
Herman Nelson was merged into Amercan Air Filter some decades ago. These units have been out of production at least that long. You'd probably have to have something custom-made.
Post some pics if you can.All Steamed Up, Inc.
Consulting0 -
The mechanism I'm trying to repair is the screw and gear assembly pictured.0 -
The teeth look OK, and the engagement... what is it they aren't doing, or needs repair?Br. Jamie, osb
A good machine shop can replicate most any part. 3D printers can do amazing replication also in most any material.Bob "hot rod" Rohr
Living the hydronic dream0
- 117 Geothermal
