Problem Solved
joeyeco27
Member Posts: 2
I have an older home built in 1864. Since I recently bought the home I had constant issues with the heating system including but not limited to constant banging. The banging and noise was so bad that it kept me up all hours of the night. I hired numerous plumbers to come fix the issue but all were unable to do so. I figured there was nothing that can be done and I would have to deal with it. It wasn't until I reached out to Matt " Mad Dog" Sweeney, that everything changed. Matt was our consultant on this issue. Within a short time period he was able to create an analysis and trouble shoot our home's issues. Based on his flawless instructions and amazing expertise, the problem is now solved !
4
So, what exactly was the problem?All Steamed Up, Inc.
Consulting0 -
Thank you, Joseph, it was a pleasure helping you out. Steamster...A Back- Pitched pipe, Filthy chocolate pudding water quality, zero maintenance in 10 years.
Very poor venting. This old gem has 4 or 5 separate cellars and nearly non-negotiable crawl spaces with pipe going everywhere. Every repair that was ever made was clearly evident as the old stuff was left where it fell...a Steam bone yard! 5 foot.ceilings. I found 3 old water wells, first Generation Durham System fitting, an abandoned lead service line. There was a lot of back and forth ..up and down because the areas were not all connected. I'm really happy 😊 it worked out and I'm sure the honest, hard-working 💪 Plumber who hit the Wall on this one learned alot about The Steam! Mad Dog1 -
Joe I may have located some leftover MEX for you. Ill save you a bottle mad Dog0
- 50 Industry Classes
