Sourcing free standing radiator covers
scottie_2
Member Posts: 14
Hello wall!
I am looking for radiator covers for my free standing 1 pipe steam radiators. I have some existing metal covers on some radiators, and looking for similar ones for the other uncovered radiators. I tried finding them local (greater Boston area) but didn’t find any. I found one source online (shutter shack NY) but was quite surprised by the cost $$.
Anyone know where I can still find these?
thank you
thank you
https://arscometals.com/products/covers/
Purchased several from here. Very good quality. Price: not so cheap but not too expensive either.0 -
That type of cover will reduce the radiator's output by about a third, and your fuel consumption will reflect it.All Steamed Up, Inc.
Consulting0 -
@slamdunk thanks for the reply. They look more affordable than the place I found.yes steamhead I’m aware of the covers affect on heat output. It’s a shame to cover these radiators, but the house is going to be rented with children. Don’t need a burn liability. I remember Dan Holohan posting a story about a lawsuit from tenant getting burned from a radiators not too long ago1
@scottie_2 , if the tops of the covers have grilles, more of the heat can get out of the cover.
We had some articles on the main site showing this, but I can't find them quickly.All Steamed Up, Inc.
Consulting0 -
President
HeatingHelp.com0 -
Thank you for the radiator covers feedback as it concerns efficiency. The problem with covers is finding ones that will work better, like some that are in the article linked above. I guess I could drill holes in the tops….
here is the article I was referring to as a landlord’s liability with steam radiators: https://heatinghelp.com/blog/the-case-for-radiator-covers/0 -
I found one a long time ago in Miami that i just use as a catch-all by the front door. It's cast and almost as heavy as a radiator by itself. The top is just poured concrete. I'd make more like it if i had free-standing rads.
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
That is probably the best one I have ever seen0
- 117 Geothermal
