Watts F&T trap--need help finding replacements
Saldanah
Saldanah Member Posts: 37
Does anyone have guidance on where to buy replacements for 2-inch traps that say:
Model: WFT, PMA 250 psi, TMA 450 degrees F, Max Diff. Press. 15, Size 2
There is a serial number: 0208W
We have a condensate pump in the building and there doesn't seem to be a way to get rid of the F&T traps.
Thank you!
    Steamhead Member Posts: 18,453
    Consulting
    Saldanah
    EBEBRATT-Ed Member Posts: 20,137
    You can replace it with another brand of trap. Watson McDaniel, Barnes and Jones, Tunstall Associates, Hoffman. Check the capacity charts as all traps with the same pipe size do not necessarly have the same capacity.
    If your looking for parts try Tunstall or B & J
    Saldanah
