domestic hot water issue on 3rd floor
nytech28
Member Posts: 116
hello , I have customer saying he has no hot water in his faucets or kichen in his 3rd floor apt , I check the domestic hot water tank it fires up, pipe is hot but not getting hot water to apt, pressure seems to be good , seems like something going in the apt, any idea that can help fix this issue.
It sounds like a hot/cold cross connect. I used to see it a lot when a mop sink with a Wye hose attached had the hot and cold valves open and the mixed valve was closed. It usually effects a nearby unit with common plumbing.
More often now I see it in aftermarket shower heads with shutoff on the head. People leave the valves on but shut off the head. This allows the hot and cold to mix , usually causing an issue in a nearby unit."If you can't explain it simply, you don't understand it well enough"
Albert Einstein2 -
not sure what changed , but the tanent saying since he moved in , hes not getting hot water in his bathroom meaning his sink faucet/bathtub & kitchen, all units gets hot for few seconds & then gets cold again,i.ll probably have to get plumber involved hvac techs dont get involved in that type of plumbing issues , I just wanted to help out.0
Any single handle shower valves? They can cross when the cartridge goes bad.Bob "hot rod" Rohr
it's a single handle shower head0
- 116 Geothermal
- 169 Indoor-Air Quality
