Recommendation on PRV
zepfan
zepfan Member Posts: 449
Looking for a suggestion on a PRV to replace the one that is show. Something with a 45-75 range that is compact, and if ever needed the homeowner could adjust the pressure. Thanks to all
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,033
    Hi, I’m not sure what brand you have there… maybe Zurn. But measure the length of the valve body and get something that matches. It should be a pretty straightforward job with the union and threaded end. If the line can be pulled away from the wall some, so you can more easily screw the valve into place, that would be nice. Otherwise you can remove the bell shaped part and replace it once the valve is in place.
    Yours, Larry
    Mad Dog_2
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,452
    The Great Larry to the Rescue.  Boy I wish you didn't live on the other side of the Rockies!!  I can't wait till the next Wetstock  mad Dog
    Larry Weingarten
    hot_rod Member Posts: 26,998
    Caleffi makes inverted style valves, very little pressure drop at high flows, super easy to clean and rebuild.
    Compact version has 1 Union end for shorter length. Gauge for setting and pressure shooting.
    Sweat, press, threaded and Pex connections available
    zepfanMad Dog_2
  • kcopp
    kcopp Member Posts: 4,636
    I really like the Caleffi 535351HA Built in unions. Easy tool free adjust.
    zepfanMad Dog_2
  • Mad Dog_2
    On the last two Burnham V-9s we did,   we  have used the Caleffi feeder valve with Guage.....  Its the easiest feeder valve I've ever used...They are in our starting lineup from now on   Mad 🐕 Dog.  Do they make them in 🇮🇹 It-lee, Hot 🔥 Rod?  Have you been to the 🏭 factory?  Mad Dog
    Yes the PRVs are made in Italy. That 535 is the worlds most recognized reducing valve, we sell that in 92 countries. It’s sold as a private label product also, to the marine industry for example. There are millions in use around the world.
    Lucky me, I’ve been to the factory 8 times over the years with customers in tow. Arguably one of the cleanest most modern brass manufacturer you will find.
