Recommendation on PRV
Hi, I’m not sure what brand you have there… maybe Zurn. But measure the length of the valve body and get something that matches. It should be a pretty straightforward job with the union and threaded end. If the line can be pulled away from the wall some, so you can more easily screw the valve into place, that would be nice. Otherwise you can remove the bell shaped part and replace it once the valve is in place.
Yours, Larry1 -
The Great Larry to the Rescue. Boy I wish you didn't live on the other side of the Rockies!! I can't wait till the next Wetstock mad Dog1
Caleffi makes inverted style valves, very little pressure drop at high flows, super easy to clean and rebuild.
Compact version has 1 Union end for shorter length. Gauge for setting and pressure shooting.
Sweat, press, threaded and Pex connections availableBob "hot rod" Rohr
Living the hydronic dream2 -
On the last two Burnham V-9s we did, we have used the Caleffi feeder valve with Guage..... Its the easiest feeder valve I've ever used...They are in our starting lineup from now on Mad 🐕 Dog. Do they make them in 🇮🇹 It-lee, Hot 🔥 Rod? Have you been to the 🏭 factory? Mad Dog
Yes the PRVs are made in Italy. That 535 is the worlds most recognized reducing valve, we sell that in 92 countries. It’s sold as a private label product also, to the marine industry for example. There are millions in use around the world.
Lucky me, I’ve been to the factory 8 times over the years with customers in tow. Arguably one of the cleanest most modern brass manufacturer you will find.
Living the hydronic dream0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
