Best soot removal method.
kcopp
Member Posts: 4,611
In your experience what is the most effective way to remove from the side of a home. Cement/ Hardie type siding. I have a house where the appliance got fouled thereby sooting up the outside of the siding. I would not want to just start spraying water, detergent etc. w/o a solid plan. TIA
You want to remove the soot, right? I'd try warm water and MEX first. Mad Dog1
Thanks0
Have your tried spray 9 ,I ve had good luck cleaning all sorts of soot and dirt and nasty boiler mud works pretty well and a great tough grease cutter also a disinfectant .
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating2 -
hmmm. Never heard of Spray 9. I will look into it...
Me neither. You guys ever heard of ZEP-45? Used it 35 years ago. It was MUCH better than WD-40, but had all kinds of warnings on the can..."banned in California...blah blah." Probably banned now or watered down version. Mad Dog1
TSP with warm water.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Sometimes there is just no way to get it perfectly clean again. The next best thing is to paint over it. BUT THAT DON'T ALWAYS WORK. If you do need to go that way, use KILZ oil based paint to seal the surface otherwise the carbon will migrate thru the paint.
Ask me how I know!Edward Young Retired
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
