System 2000 domestic hot water
grumpy47
Member Posts: 5
Hi Larry, The system is not keeping up with hot water while taking a shower. After running the shower for 3or 4 minutes the water coos rather quickly. I suddenly have more shower water pressure but less duration of hot water. Thanks
Hi @grumpy47 , Have you tried a crossover test to see if the problem might be out in the plumbing somewhere?
Yours, Larry0 -
When is the last time the plate heat exchanger was properly flushed?
Thank you for your question, @grumpy47 .
Very little heat is reaching your (likely) 40 gallon or larger storage tank. If you have a continuous call for hot water on the manager, it is not your tank thermostat. If you have a plate heat exchanger, it could be the domestic bronze circulator or possibly a fouled plate heat exchanger.
Your heating pro can probably figure it out quickly.
Hot water diagnostics start on p.18 in this hot water manual.
Best,
RogerPresident
Energy Kinetics, Inc.1 -
- 123 Chimneys & Flues
