Header, because
STEAM DOCTOR
Member Posts: 2,553
He got the Hartford loop correct.
Those Slant Fins make very dry steam, I suspect due to the unique internal path of steam in the boiler through the full depth of the really wide end section and the internal baffling. Also really easy to get a good skim. Probably the best Cast Iron boiler design on the market.To learn more about this professional, click here to visit their ad in Find A Contractor.2
Unfortunately, they're no longer on the market. R.I.P., Slant/Fin.The Steam Whisperer said:Those Slant Fins make very dry steam, I suspect due to the unique internal path of steam in the boiler through the full depth of the really wide end section and the internal baffling. Also really easy to get a good skim. Probably the best Cast Iron boiler design on the market.
Consulting2 -
I would imagine just putting in a 3inch riser would fix most of the problems. As long as your input is below 200,000, velocity in a 3 inch riser is low enough for water to drop back. Not that I would recommend that long term.To learn more about this professional, click here to visit their ad in Find A Contractor.1
If the boiler water starts getting fouled, I think you will still get some carryover, so the header probably helps with that.To learn more about this professional, click here to visit their ad in Find A Contractor.1
I concur0
Hilarious.. love it. Don't make me dig back in to my picture archives!! We used to have a "wall of Shame" contest on the Wall. I contributed many a doozy....amazing they work fine sometimes. I did actually cure a bad steam job with 3" drop header risers that went all the way to the ceiling before dropping back down. Ill try to find the picture. Long Story short. Genius local knucklehead rerouted both steam mains to about 5 feet off the floor during a basement finishing project. Sheetrocked and painted..not working...not good. I get called in. Wasn't sure if it would work, but I went for it and solved it. Wild looking header but
Fixed at the boiler without touching the sheer rock. Mad Dog 🐕1
- 15.8K Strictly Steam
