Lochinvar boiler
chief
chief Member Posts: 34
Hello all, I am considering to replace my old buderus gb142 boiler with a Lochinvar nkb110L. Heating only, not a combo model. Unit will run on LP of that makes a difference.
Any input is appreciated.
    hot_rod Member Posts: 27,417
    I’ve owned most every model mod con Lochinvar has built, excellent service from all of them.
    I like the control options on the Knight models. I have one in my shop now and you can really dial them in to the exact application.
    Add the Conxus module to remote monitor and adjust the boiler, is that appeals.
  • HomerJSmith
    HomerJSmith Member Posts: 2,774
    edited February 2023
    I like Lochinvar, just installed one on a SIM project (WHB110N). You will need a nat gas to propane conversion kit. Make sure you understand the conversion process and the kit application to your boiler before attempting it.
