Lochinvar boiler
chief
Member Posts: 34
Hello all, I am considering to replace my old buderus gb142 boiler with a Lochinvar nkb110L. Heating only, not a combo model. Unit will run on LP of that makes a difference.
Any input is appreciated.
I’ve owned most every model mod con Lochinvar has built, excellent service from all of them.
I like the control options on the Knight models. I have one in my shop now and you can really dial them in to the exact application.
Add the Conxus module to remote monitor and adjust the boiler, is that appeals.Bob "hot rod" Rohr
Living the hydronic dream0 -
I like Lochinvar, just installed one on a SIM project (WHB110N). You will need a nat gas to propane conversion kit. Make sure you understand the conversion process and the kit application to your boiler before attempting it.0
- 128 Chimneys & Flues
