Indirect radiation replacement
JamieP
Member Posts: 27
We have a project where 7 of 15 indirect radiators cracked. Any suggestions on replacements options?
There is a possibility that the guts of another brad of convector might work. https://www.beacon-morris.com/residential-and-commercial-convector.
Another options might be to stack some baseboard radiator elements 3 wide by 3 high to build a home made custom fit element.
Another option is to call Governale to see if thay have something that might fit http://governaleindustries.com/products/convectors/Edward Young Retired
Use this Beacon Morris chart to determine the output capacity of what you have.
Possibly a panel radiator could swap into that space, a #33 version. The panel radiators would look nice in those recess and give you both convection and radiant heat output.Bob "hot rod" Rohr
Living the hydronic dream0
- 50 Industry Classes
