Boiler pump
Good morning. I have a Lasrs endurance EBP175. This morning I check my boiler and no call for heat or hot water. But the internal pump keep running.  What could be the cause ?  Please help
    EdTheHeaterMan Member Posts: 11,555
    edited February 2023
    The transfer tank may be calling for heat if the transfer tank is less than 40°F (22°C) below the Off Point. Now if a temperature sensor is malfunctioning the transfer tank call for heat may be keeping the circulator on while the high limit has the burner off. But that is just one explanation. There may be others. Are there any error codes displayed?
    You can try the reset button to see if that puts everything back in step.
    You can also see whet the temperature sensors are reading.
    6.3 View Menu
    The boiler control allows the user to view the
    temperatures that are being read by the sensors.
    The default display for the boiler control is the
    supply temperature (defined below). To scroll through
    and view the other readings, press the up or down
    button.
  • ArchimoreHorie
    ArchimoreHorie Member Posts: 27
    I was out. But will check it. I know the screen was saying. On.
  • ArchimoreHorie
    The boiler just say on.
