nest thermostat
DaveM
DaveM Member Posts: 77
good morning
my daughter bought a house recently she has forced air for cooling and hydronic baseboard heating thru a gas fired boiler obviously two separate systems. right now there are two separate thermostats on the wall next to each other. can I wire the heating side of the nest to the boiler in the basement and the cooling side to the air handler in the attic. thanks so much for feedback Dave
  • SuperTech
    SuperTech Member Posts: 2,661
    Yes, no problem.  Boiler goes to RH and W. A/C to RC, Y, G and C.
    STEVEusaPA
  • STEVEusaPA
    Remove jumper between R and RC, if there is one equipped for regular thermostats, in case any non-nest users comes across this thread.
  • DaveM
    thanks thats what I thought
