Small drip out of bottom of taco 220 flocheck valve
I have the ever slightest of drips out the bottom plug of this flocheck valve. Can I just give it a little tightening (I’m assuming tight is clockwise), or do I need to replace the plug?
Go ahead and try tightening it. Clockwise.0
Yes! I did! I was on the wrong loop. It was as you said. Works perfectly now.EdTheHeaterMan said:Did you ever get the zone with the orange tape to purge?
And, Oh yea... what @Gilmorrie said0 -
And, Oh yea... what @Gilmorrie said1 -
Is the plug leaking or is the packing on top leaking and running down the side?
If it is the plug might need to pull it out and put some new dope and teflon tape on it.0 -
Pretty sure it’s the plug. I gave it a clockwise crank, but no joy. It’s so little that im thinking to wait until the spring to do it. I put a small cup there. So I can just clean it up, but some new dope and tape? I don’t need a new one?mattmia2 said:Is the plug leaking or is the packing on top leaking and running down the side?
@rob2816 said "So I can just clean it up, but some new dope and tape?"
Yes. Wire brush everything. An old copper tubing fitting brush will work on the inside threads. Teflon tape and dope. Put a little dope on the inside threads.0 -
Right again! It was the packing nut NOT the plug. You would win HVAC Jeopardy.EdTheHeaterMan said:
Also use a back up wrench on the HEX of the flo-valve when tightening or removing the plug. You don't want to stress the thinner portions of the cast iron valve.1 -
Packing gland, I should say0
rob2816 said:
on closer inspection, it seems like the tightening of the packing gland slowed, but did not completely stop the drip. It does not seem to be coming from the gasket of the assembly nut. It is higher than that- the drip starts right at the location of the packing gland and flows downward. Any suggestions? Thank you.EdTheHeaterMan said:
Also use a back up wrench on the HEX of the flo-valve when tightening or removing the plug. You don't want to stress the thinner portions of the cast iron valve.0 -
This is the correct material to use in a packing gland https://www.supplyhouse.com/Danco-80793-3-32-x-24-Graphite-Valve-Stem-Packing
But I have already used teflon tape as packing gland filler and I have also used Kite String and lamp wick with some pipe dope painted on the string.
@MikeAmann has the right idea, you need to add something to act as packing along with the pipe dope.Edward Young Retired
Can this procedure be done with the system pressurized or will I have to turn off the water supply and drain the boiler a bit to do it?0
EdTheHeaterMan said:This is the correct material to use in a packing gland https://www.supplyhouse.com/Danco-80793-3-32-x-24-Graphite-Valve-Stem-Packing But I have already used teflon tape as packing gland filler and I have also used Kite String and lamp wick with some pipe dope painted on the string. @MikeAmann has the right idea, you need to add something to act as packing along with the pipe dope.0
This can be completed with the pressure on the system. As you loosen the packing nut there will be some water leaking, so place a towel or bucket under the valve to collect the water. Wrap the string or tape around the stem then push the packing gland nut back in place quickly. As you tighten the nut, the leak will slow then stop.
You can reduce the water pressure in the system it reduce the leaking water, But you do not need to drain the entire system.Edward Young Retired
@EdTheHeaterMan thank you. I will try this.0
@EdTheHeaterMan that packing gland nut is hard to turn. What do you recommend to loosen this nut? A socket wrench?0
First thing is to turn the manual open knob to full open. then a socket wrench would be a good choice to get the best mechanical leverage. a 6 point socket is better than a 12 point socket for tough to move screw thread fittings. A really good penetrating oil like PB Blaster may help.
I love to see all the support for Taco products.
this one was an easy fix. If you need additional support, contact Taco at (401) 942-8000 and ask for tech support.
Joe Mattiello
Taco Comfort Solutions0 -
@EdTheHeaterMan. Thank you, Ed. I will try this.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
