Taco 007-F4 replacement
MikeSInMass
Member Posts: 4
in Plumbing
I see that this unit has be discontinued, and looks like the -f5 which has a check flow valve built in is a direct replacement. Two questions:
1. Is it an absolute replacement, I will not need to make any changes, the length (flange - flange) is exactly the same lenght as the F4?
2. I currently have two seperate Taco checkflow valves installed, can I just leave them in place, should I remove any internal components from these?
Thank you!
Thank you!
The 007-F5 would be a direct swap for what you have. You won't need to remove anything (the model that comes with the intern check valve is 007-F5-7IFC).
Thank you, My 2nd question was regarding my seperate checkflow valves, seeing that the new circulators have the checkflow built in. Do I just leave these two seperate checkflow valves in place as is?0
MikeSInMass said:Thank you, My 2nd question was regarding my seperate checkflow valves, seeing that the new circulators have the checkflow built in. Do I just leave these two seperate checkflow valves in place as is?They do not all have the check valve installed. See my post above for the different part numbers. If you can only get the IFC version for some reason, just leave the check valve out.0
The difference in the last number is just a version of manufacturing. When we do a major change, we will label it with the next number. A major change has nothing to do with replacement equivalents, performance or anything of the sort. It may mean we used a different vendor for the cast iron, a difference in bearing materials to make it quieter, things like that.
-F5 means it is a (F)langed circulator and the the 5th revision over the last 50 years.
As for purchasing with or without a check valve, they are different part numbers with -IFC on the end of the part number. You can always remove a check valve if that is the only one you have and you never want to double check. If there is an external check valve present, either order the model without or remove one of them from the system.
Dave HDave Holdorf
Taco, Inc
Thank you.
Try the 007e version, same flange to flange dimension, and more efficient. Thanks for using Taco!!Joe Mattiello
Taco Comfort Solutions0 -
Thank you, I will. Question re the flange nuts and bolts - I read that some say to install new bolts and nuts, why not reuse the old ones?0
Are they plated bolts and nuts, or rusty steel? If they are clean, in good shape you could reuse them, they are not under a lot of stress in that app.ication.
Bolts and nuts are fairly inexpensive parts🤔Bob "hot rod" Rohr
Living the hydronic dream0
- 117 Geothermal
