I think, I hope I solved my Burnham boiler short cycling problem
eclecticmn
eclecticmn Member Posts: 129
My boiler was short cycling. starts, would reach the 180 deg F limit, shut off, drop to 160 ish, restart. Some heat but not enough.
I just replaced the circulator pump. I suspect the pump was bad or the check valve was bad. There was no pumped flow. I had a gravity system. But a bad check valve would have blocked that, correct?
I wonder why the local HVAC people did not suspect a bad pump?
Here is the first topic.
https://forum.heatinghelp.com/discussion/191012/burnham-series-3-cycling-for-2-min-out-of-5-when-heat-is-called-for-insulation-layer-broken#latest
Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.
  • eclecticmn
    Also, the TT VAC issue was because when the wood stove satisfied the thermostat, there was no call for heat. When I raised the set point, then the system called for heat forever which it could not meet.
