I replaced my circulator pump on home boiler. It is leaking on one side of the lower flange.
eclecticmn
Member Posts: 129
I replaced a Grundfos circulator pump on my home boiler. It is vertical, pumping up. With check valve. I got the new gaskets and bolts. The old one came out OK and the new one went in harder and I had to lift the pipes a little bit. I nudged it over and got the bolts lined up and tightened the bottom ones to let the water rise up and maybe drive out the air. Then I opened the first valve, to the ballast tank I think and water (and air?) came out the top loose flange so I tightened them up.
The water (and air?) was hissing out the back side of the bottom flange so I tightened them up and it kept leaking out the back of the bottom flange. I took it out and looked at the gaskets to see if they looked OK. They did. There was enough leaking so I did not turn on any more water valves.
Any ideas? Should I have used faucet grease on the gaskets?
UPS15-58FC, 3-Speed Circulator Pump,
Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.
A flange is a little more forgiving than a union -- but not much. I'd suggest taking it apart again, and getting the flange halves lined up as perfectly as you can -- left, right and especially flat and parallel to each other. Then slip the gasket in and -- making sure everything stays aligned torque it gently -- go in a star or criss-cross pattern. It would be best if the pipes could be held in the correct position in some other way.Br. Jamie, osb
Thanks I will try that. Also, how do I remove a check valve on the 58FC? I may have to fall back on the old one and see that the check valve is gunked up. I only have one pump and one zone.Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.0
Flat gasket, or the o ring that fits in the groove? The flat ones can hang up if the gap it too tight to slide the pump into the opening
Flat gaskets in a square groove.Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.0
I mean the round gasket does not have a round cross section.
https://www.supplyhouse.com/sh/control/product/~product_id=519610Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.0 -
square cut o-ring, officially 😉
Those should seal fine, even with some misalignment. Assuming it stays in the grooveBob "hot rod" Rohr
Thanks to all again. I took the advice. I propped up the pump piping with a 2x4 from the floor and aligned it at ease then lowered it. So far so good. I was getting frantic.Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.0
