Taco's VT2218 Delta T circulator
Dave H_2
Member Posts: 615
OK everyone,
There has been a lot of work going on at Taco and places like this help find and get the word out. This is a followup to @Franktg78 post a little while ago.
Here is what happened with the VT2218 circulator production.
There was a display issue, not a performance issue. There is a circuit board internally between the display and the controller of the circ, basically the controller for the display.
After some exhaustive digging around, some sleuthing, testing and more testing this is what we found.
This control board did not have its software correctly installed so therefore it will not tell you the current watt draw, nor will it tell you the GPM. The circ will read "07 WATTS 00 GPM" whether it is running in Delta T mode, fixed speed mode, any mode or setting you choose. However, it will still operate in whatever mode you have it programmed. The buttons still operate as intended.
So, what is affected out there? If you have a date code that shows between 0422 and 0423, the display may be compromised. The date code represents a month and year; we predate these circs by 4 months to allow for the circulators warranty based upon the time it take to leave Taco, go to our reps warehouse, get to the wholesaler and then to the jobsite. So that means that these circs were built between December 2021 and December 2022.
If your circulator falls within the date code above, is installed and the display is working properly, there is nothing you need to do. It will not fail later. This is a right out of the box situation
What do you do about it if you have one that has the incorrect display? Contact your wholesaler and your local Taco Rep. They will help you out. This is a high priority for us here at Taco so getting replacements back out is important. We are working with supply chain to get new circuit boards and chips (these things are in such high demand; every business sector has a rough time getting them). There is no in the field fix or programming that can be done. If you have one that has not been used or installed, still contact your distributor and local Taco rep.
Any other questions, please don’t hesitate to contact me.
Dave H
Dave H
Dave Holdorf
Taco, Inc
9
Nice to see a company stand behind there product. Thank you!0
Nobody stands behind their gear like Taco. Any issues, no questions asked. The Taco People i.e., The White Family, Dave Holdorf, John Barba and the rest show their client contractors great love and respect! Thanks again for helping me out the other day Dave! Mad Dog 🐕.2
Hi Dave H. I just need clarification. In your post above (thank you for acknowledging the defect) you say that other than the display, all should be functioning. That's not the case with me or sounds like, @Franktg78 . Not only does the display not work as you stated, but it stays on one speed. The Delta-T does not modulate at all. I can't even get the speed to change in Constant Speed mode. Can you please clarify that the electronics are bad entirely and not controlling the motor correctly? I'm on my second with this issue. Thanks1
Dave, Sorry to disagree, but I'm observing the same malfunctions as jwilliamadams and franktg78 with both the display and performance. I observe a single speed circulator with an accurate dual temperature display regardless of program. I hope that you are able to share more details now on what Taco is doing about this.Retired and working on restoring an 1888 Victorian with heating upgrades1
Taco did not request a return of the old vt2218 when they sent a new one. So, being curious, I disassembled and reassembled it to see how it's made. I took pictures to share. It's a lot like other ecm motors, but this has separate display and control boards (not potted, assembled in Mexico). The boards and stator connect with fixed pins, just the display is on a ribbon cable, which was a bit awkward in reassembly. I have it working back in it's defective state. I don't like waste and might be useful as a single speed circulator on a relay, so I'll just keep it in case that need arises at home, then I would get more measurements on performance. Meanwhile the warranty replacement is going in nowRetired and working on restoring an 1888 Victorian with heating upgrades2
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 392 Solar
- 55 Water Quality
- 46 Industry Classes
