1107-1
Nav
Member Posts: 1
in Gas Heating
I have 4lights flashing on panel top one is red bottom one is green and have no heat
Cryptic
So Far. Google has indicated the above topic equals 1106. (1107 - 1 = 1106)
and Milwaukee tools makes a D handle Drill with that model number.
The search goes onEdward Young Retired
On what equipment ?
Make,Model ?0 -
We are supposed to guess. This is a test. See who can detect the answer to the cryptic clueDerheatmeister said:On what equipment ?
Make,Model ?Edward Young Retired
In that case I'll bet a bad HSI..(hot surface igniter)0
This has a spark to pilot ignition sequence... NO HSI. When was the last time you had maintenance service? I would check the pilot flame sensor. The bottom green and top red flashing usually means that there is a pilot flame when there should not be a flame at all. Look at the pilot to see if there is a flame before the flame should be there.
1
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
