1107-1
Nav
Nav Member Posts: 1
I have 4lights flashing on panel top one is red bottom one is green and have no heat
    EdTheHeaterMan Member Posts: 12,158
    Cryptic
    So Far. Google has indicated the above topic equals 1106. (1107 - 1 = 1106)
    and Milwaukee tools makes a D handle Drill with that model number.
    The search goes on
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    On what equipment ?
    Make,Model ?
    On what equipment ?
    Make,Model ?
    We are supposed to guess. This is a test. See who can detect the answer to the cryptic clue
  • Derheatmeister
    §1107-A. Unlawful possession of scheduled drugs
    109A_5 Member Posts: 3,993
    My guess.
    one is red bottom one is green = 2, not 4 ???
  • kcopp
    kcopp Member Posts: 4,675
    In that case I'll bet a bad HSI..(hot surface igniter)
    edited February 2023
    This has a spark to pilot ignition sequence... NO HSI. When was the last time you had maintenance service? I would check the pilot flame sensor. The bottom green and top red flashing usually means that there is a pilot flame when there should not be a flame at all. Look at the pilot to see if there is a flame before the flame should be there.
    109A_5
