Weil Mclain HE 2 series 1
inspkerr
Member Posts: 40
Hello, had to switch out the controller on 1991 HE-2 they are recommending a 1013-200 control. the manual for the new control is saying if I have a B&G 100 circulator on this system, I should also get a 120-volt isolation relay with one set of normally open contacts can you recommend a relay for this ? THANK YOU - Paul
RIB, Relay In a Box, use the 120 volt coil.0
Thank you , can you specify a part or model of this RIB ?0
- 117 Geothermal
