Identification and EDR for ceiling/duct mounted convectors, 1885 vintage
NealJ
Member Posts: 43
I’m trying to validate system/boiler sizing in this 1885 house museum. I’ve got the radiators done, but I can’t identify the basement convectors and don’t know how to find the EDR. These are typically inside a box with ducted air flow. Those shown are disconnected and I’m going to attempt to pull the tie rods in place and disassemble (because I have no idea how I’d get it down from the ceiling whole). It appears the sections connect with spherical male/female joints that might have gaskets that I may be able to clean up and reseal. Anybody recognize these? Any idea how to calculate EDR/BTU? Some have more sections than others, just like radiators.
1
I have what look like very similar, if not the same, rad. There are no markings on it, but its supply / return connections are different than the Bundy Ed suggested.
A local steam expert estimated 60 sq ft. on this single rad. Since you have two it'd be safe to say you have ~100-120 sq ft. there.
Here's a PDF that can help with estimates: https://smithfieldsupply.com/company_info/forms/radiatorest.pdf0 -
Thanks so much for this! Of the 16 individual radiators in the basement ceiling, two of them are just like yours (only more segments). Not sure why two are different, it’s possible they were added later.NYtimebomb said:I have what look like very similar, if not the same, rad. There are no markings on it, but its supply / return connections are different than the Bundy Ed suggested.
1
- 121 Chimneys & Flues
- 15.8K Strictly Steam
