Is this a steam or hw radiator?
guzzinerd
Member Posts: 451
It's available for under $100 not too far from me.
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Would be for my 2 pipe steam system, looks like can take it then.
@guzzinerd that radiator will work on two pipe steam; however, the existing hybrid radiant convectors in your building will heat very differently from this one which contains much more metal, therefore will heat up and cool down more slowly. Most likely if you put this one in, it will overheat the room compared to the others.—
Bburd0 -
Good to know. Can the valve adjustment help regulate the heat or when it's hot it's hot? Would be in a spot where a much larger convector was locatedbburd said:@guzzinerd that radiator will work on two pipe steam; however, the existing hybrid radiant convectors in your building will heat very differently from this one which contains much more metal, therefore will heat up and cool down more slowly. Most likely if you put this one in, it will overheat the room compared to the others.
.I've taken up getting my old system up to snuff why stop now?Long Beach Ed said:Prepare to learn the advanced art of 95 year old steel plug and bushing liberation.Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
Appreciate it. I'd like to replace 5 missing convector rads with real radiators. Unless you guys think the floor board models they stuck in will do the job once i put traps on them?bburd said:Unfortunately I'm not aware of any modern replacement that will match the thermal mass and heating characteristics of your original radiation.If you're going to install that one, I suggest putting a TRV on the steam supply and bringing it in at the top. That should control overheating.Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
you can still buy numerous styles of convector cabinets.0
- 50 Industry Classes
