Is this a steam or hw radiator?
It's available for under $100 not too far from me.
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
    EBEBRATT-Ed Member Posts: 20,394
    Sections connected top and bottom can be used on steam or water. Connected on the bottom only is steam. Looks like steam & water to me. If it was used on water you may have to drill and tap for the steam vent if your on a 1 pipe system. Looks like it has the boss on the rad to drill it
    guzzinerd
  • guzzinerd
    guzzinerd Member Posts: 461
    Would be for my 2 pipe steam system, looks like can take it then.
  • bburd
    bburd Member Posts: 1,314
    edited February 2023
    @guzzinerd that radiator will work on two pipe steam; however, the existing hybrid radiant convectors in your building will heat very differently from this one which contains much more metal, therefore will heat up and cool down more slowly. Most likely if you put this one in, it will overheat the room compared to the others.
    Bburd
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,843
    Prepare to learn the advanced art of 95 year old steel plug and bushing liberation.
    guzzinerdmattmia2
  • guzzinerd
    Good to know.  Can the valve adjustment help regulate the heat or when it's hot it's hot?  Would be in a spot where a much larger convector was located
    .I've taken up getting my old system up to snuff why stop now?
  • bburd
    Unfortunately I'm not aware of any modern replacement that will match the thermal mass and heating characteristics of your original radiation.
    If you're going to install that one, I suggest putting a TRV on the steam supply and bringing it in at the top. That should control overheating.
    Bburd
    guzzinerd
  • guzzinerd
    Appreciate it.  I'd like to replace 5 missing convector rads with real radiators.  Unless you guys think the floor board models they stuck in will do the job once i put traps on them?
    mattmia2 Member Posts: 17,206
    you can still buy numerous styles of convector cabinets.
  • guzzinerd
    Thanks. You recommend anyone?
