NAVIEN NHB-150 or Energy Kinetic Accel CS
RichRios
RichRios Member Posts: 3
Which one should I go with ?
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,241
    What’s important to you? What kind of domestic hot water demands do you have? Do you have adequate floor space to fit an indirect tank?
  • RichRios
    I have a 35 year old EK1 2000 with a 40 gallon tank
  • Hot_water_fan
    edited February 2023
    Do you have any high GPM DHW loads? Like tubs, stuff like that. The Navien, because it’s a combi with an input of 150kbtu, can get you about 3.5 gpm max. An indirect can exceed that for short periods, and based on the size of the boiler can match it indefinitely. You can also go smaller because you have a tank, if that fits the heat loss better
  • EzzyT
    EzzyT Member Posts: 1,379
    EK Accel every day of the week
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    HVACNUTSuperTech
  • RichRios
    I have 1 tub…..3 bathrooms and 4 heating zones
  • kcopp
    kcopp Member Posts: 4,646
    Never navien for me...
    That being said there are more options than these 2.
    Chose the installer over the product.
    Chose the best product that the installer knows backwards, forwards and upside down.
  • SuperTech
    SuperTech Member Posts: 2,647
    Anything but Navien.  Energy Kinetics have never disappointed me. Installing contractor is usually more important than the brand name.
    HVACNUT Member Posts: 7,318
    IMO, not only is the Accel a better boiler, you can actually get your hands in there to service it.
    GGross
