LAARS Endurance Boiler (pre-2005 model) getting L.O. lockout code every few days
lleone
Member Posts: 1
I have a LAARS Endurance Boiler that runs fine for 2 or 3 days and then goes into lockout (L.O.). After I hit the reset button it will work for another couple of days before going into lockout again. This has been going on for about 3 weeks. Any ideas as to what might be the cause?
1 - poor combustion
2 - poor flame sensor signal
3 - inadequate gas supply
4 - ignitor failure
5 - blocked or contaminated air source
I'd start by checking and cleaning the flame sensor rod0 -
What is the lock ut code?0
Here is the manual. http://www.laars.com/LinkClick.aspx?fileticket=2pLC8nYa9A4=&tabid=1609&mid=4036
I would pay close attention to the venting. I have seen the inner pipe rot out and cross contaminate the combustion air. This kind of damage hard to detect and can create a CO poisoning risk to the occupants.
I would not spend much money trying to troubleshoot and repair an endurance. 10-15 years seams to be the average lifespan for that boiler."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I have a similar problem regarding the LO code. I see where it is said the life of this boiler may be up. any suggestions as far as a new replacement boiler? ?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
